AT-Style Power Supply Question
TroganTrogan London, UK
edited April 2007 in Hardware
Can someone briefly help me answer the following please....
Lets say an AT-style power supply does not have any markings on the connectors. There are also no markings for the power supply connector on a motherboard.
How can I make sure the power supply works?
Thanks in advance!
  • CycloniteCyclonite Tampa, Florida Icrontian
    edited April 2007
    Plug it in, stand in a pool of water, and stick your finger in it. If you're not lying on the floor limp, drooling on yourself, then the power supply doesn't work.
    edited April 2007
    I forget, aren't AT supplies turned on by a switch on the power supply itself? If that's the case, you could just plug a fan into it or something and see if it spins up when the PSU is turned on.
  • KentigernKentigern Milton Keynes UK
    edited April 2007
    Hi Trogan
    Is this what you are asking about
    if so the old saying we used to have was "black wires together in the middle"
    edited April 2007
    AT power supplies just turn on. Get a voltmeter and test black/red, black/yellow for 5v and 12v power (I can't remember which applies to which).
  • GHoosdumGHoosdum Icrontian
    edited April 2007
    I dug up a pinout diagram for AT PSUs, in case it helps:
    http://pinouts.ru/Power/MotherboardPower_pinout.shtml
