Home Made Surround Sound Help...
*Waves to all the icrontic people*
My problem is pretty basic. I have a 2.1 speaker system and want to hook it up to my stereo. The stereo has an "audio out" port on the back as well as the classic hook up for the speakers, positive and negative wires with no ends on them.
Basically...this is the set up I'm looking for...
-CompSpeaker- -StereoSpeaker-
-StereoSpeaker- -CompSpeaker-
So....how do I hook my stereo up to my computer? What connections should I be using? Do I have to hack some wires to make it work? It really doesn't matter to me, I just want it working.....
-Subwoofer-
Do you have a 5.1 sound card with outputs?
Exactly....now how do I do it?
Yup. Not sure about my sound card though....splicing wires doesn't really phase me though so I don't think that'll be an issue...
Are you hooking the stereo to the computer or the computer speakers to the stereo?
Ideally, the stereo to the computer since I assumed it'd be easier but either way...
I just want more sound...
Look at your sound card, how many outputs does it have?
3. Green, blue and pink....
