Help on first build
saltydog806
Bowie MD
I have finally started installing my new MOBO. I notice that I can plug in the Pwr Led, the power switch, reset switch ect one way or reverse it 180 degrees and plug them in. The Mobo manual shows the # 1 pin but how do I know what the # 1 pin is from the case leads? The manual for the case is no help.
Thanks all
:bigggrin::bigggrin::bigggrin::bigggrin::bigggrin:
