Need help: Web site will not load
vanagon40vanagon40 Indiana Member
edited Jun 2017 in Internet & Media
Long time member but my last post was in 2014. This was always my go to site for computer problems (so my absence is a good thing for me).
I am stumped. www.imagevenue.com will not load on my home computer. To my knowledge, last night was the very first time I tried to open the page and it simply stalled. I have no problem with any other page that I am aware of. I tried turning off my anti-virus and ad blocker, but no help. The page loads fine on my office computer and I have essentially the same systems and extensions on both, Windows 10 Pro. I tried with Firefox, Chrome, and Edge, all with no success. I searched the register for a "imagevenue" entry, but found none.
I am able to view images hosted at imagevenue, but the format for the image does not start with "imagevenue."
For example: http://img208.imagevenue.com/img.php?image=th_140342278_42baseball_122_451lo.jpg
Any suggestions?
  • vanagon40vanagon40 Indiana Member
    edited Jun 2017
    I thought I should be able to edit my original post, but I do not see how to do so.
    UPDATE: I was able to access the website using a VPN. Why would that make a difference? This is my home computer and I have not knowingly installed any type of content blocker (other than Adblock Plus and Webroot SecureAnywhere).
    So, a good general "is it just me or everyone?" place to look is any of a number of sites that check for up status like this
    In your case, this was up.
    You could try a couple things:
    0) never not restart ;)
    1) from CLI, ping www.imagevenue.com from your machine off VPN
    2) if that resolves, you can tracert www.imagevenue.com (assuming windows). It will basically go through a bunch of hops to get to the destination server. If it gets above 30, you can stop it anyways.
    3) if that works, we're at a weird spot where you should be clearing/defaulting network settings and/or browser settings (often related to proxy, or dns)
    What are you referring to by "register"? registry of domain names? My preferred web-based tools for internet troubleshooting showed
    edited Jun 2017
    Tushon, thanks for the response. It was just me, the site was not dead.
    The next part is way over my head.
    The last is I should have said registry. I ran "regedit" and then "Find..." under "Edit" and entered "imagevenue". I thought I might find a registry entry with a list of blocked sites. I found nothing.
    I still do not know what is blocking me.
  • SonorousSonorous F@H Fanatic Virginia Icrontian
    CLI is the command prompt. You can right click on the windows icon and select "Command Prompt" with administrator. From there you can run the commands Tushon posted.
    I followed the instructions and it is still way over my head. I did this on my office computer where I have no problem loading the website. Might as well be written in Greek.
    click the image for a full size view
  • PirateNinjaPirateNinja I don't know how to not Icrontian
    What's the error message in your browser after it fails to load?
    I'm not sure. Now it is loading fine, with or without the VPN, on all the browsers.
    Maybe I'm not smart enough to own a computer? image
  • AlexDeGruvenAlexDeGruven Not as tall as Bobby Tallbeer. Twilight Sparkle is overrated. Meechigan Icrontian
    Sounds like you had a stale DNS entry cached somewhere that finally timed out and got refreshed.
The 5¢ Tour
