Need help with SLI connection HELP!!!!!!
Well my video cards are suppoesd to be SLI compattable but a friend has come to me and told me that the video cards arent so what can i do to find out if they are compatible or not ..... by looking at them or is there something that is suppoesd to come in the box that would tell me how the SLI connection would work....... just need help before i throw the extra video card in the carbadge
:headbange
:headbange
All SLI cards will have a tab on the top forward part of the graphics card.
this is for Motherboards that need a crossover to attach them together...
also all SLI Mobo's will come with a Connector like this!
* Note some MObo's do not require this connector!
So i have the video cards and they have that little peice on the clip art u showed now i need to know were i can buy it from and how much it costs please ...... cause i really dont wanna waist my video cards its 2 6600 gt's and what kinda of graphics would that match up 2 such as 2 6600's = 1 7800
2 6600's = 1 6800gtx or what ???
Here's a picture of one of the cards. They're both the same.
EDIT: The cards say nothing on them about being SLI compatible, I think lastsight just made a bad decision on where he gets his parts from...
The card you posted above is not a SLI card!
this is an SLI 6600GT! if your Card looks nothing like these than they are not SLI!
http://www.leadtek.co.jp/download/VGA/PCI-E/PX6600GT/PX6600GT_TDH-PCB.jpg
http://img.zol.com.cn/article/3/596/liCLYRKjCLkKI.jpg
http://www.amdzone.com/pics/videocards/asus/6600gt/card.JPG
http://www.dcs-online.biz/shop/images/images/4631.jpg
http://www.chaintech.com.tw/tw/images/Products/VGAcard/SE6600G_L.jpg
http://www.kohryu.com/picture/inno/gf6000/6600gt.jpg
http://www.servodata.com.pl/images/pny/verto/6600gt_pcie.jpg
http://www.levi.cz/image/AsusN6600GT.jpg
http://common.ziffdavisinternet.com/util_get_image/10/0,1425,sz=1&i=108241,00.jpg
http://image2.sina.com.cn/IT/cr/2005/0926/391403500.jpg
http://s90782290.onlinehome.us/wp-content/photos/sa6600g_L.jpg
http://www.computery.ru/upgrade/numbers/2005/217/img/VIDEO_DSC_5657.jpg
http://apluscomputers.co.nz/images/6600GT.jpg
http://media.hardwareanalysis.com/articles/small/11330.jpg
http://www.cbcnz.com/images/2225.jpg
I have a better idea if the card above is the one you have than it isn't SLI. If the IMage TheGr81 posted isn't your card than take an image of it I can tell you if it is SLI within an instant!
This card looks very close if not the same card as in your picture. Note that is does not have the SLI connection on top, but is a SLI ready video card.
www.newegg.com
Are you sure about that? As far as I know the standard 6600 cards aren't SLi compatible, only the GT cards are....and that link you gave doesn't say anything about SLI at all.
Can you put a better pic up that identifies the notch? No notch = No SLI.
edit: After a bit more research on nVidia's site I found this page about building an SLI system. If you scroll down, you'll see that there are cards under a 6600 GT that are SLI ready, but don't use the SLI connector.
True!
And make sure to do it with the 80.xx drivers!
these are the only 2 I can find a 128MB version and a 256MB version both not GT's they are regular 6600's
ASUS always tags there cards with there LOGO! his card is logo free!
Lastsight - Can you confirm the brand?
There are 6600 and 6600LE Cards, certified as SLI compatible (See Nvidia SLI Certified on their site) that are SLI compatible, and DO NOT have SLI connector.
Guess they dont need the bandwidth
