Question on power wires and cables??????
Is there anything to consider when routing cables and power wires (household voltage) such as a USB 2.0 running parallel to a 110v power cord? Will the power cord cause any loss or corruption issues? I am putting the finishing touches on my system and would like to know. TIA!
then i would say it's best not to put it near power lines. Because ordinary USB cables lacks the shielding that it's needed against interfrence from the power lines.
For long runs, shielded cables next to a power cord would not be good. For short runs, like 12 feet or less, probably not much needed for most USB uses. Safest is to to keep all power cords away from data lines as much as possible, or use good cables like you appear to be doing, mtgoat.
John D.
But, I have external cables going every which way....
John D.
Avoiding the problem lies in using good quality, preferably shielded, cables.
