Sound problem
Ok i have a problem with my sound, i formatted my pc...now im up and running again i have no sound, when i goto control panels sound options i cant click anything...i dont have the disks that came with the pc because its my friends pc ( im using it while hes visiting his mum in scotland )
Its an Intel Pentium 4 2.53 GHz...not sure what other infomation you might need to help me, if you need any more infomation about the pc, tell me what info you would need
Thanks in advance
Thanks in advance
We can track down integrated sound drivers for you then.
All we need is the manufacturer of the motherboard (ASUS, ABIT, Gigabyte, etc...) and the model number (KG7, IS7, K8V-DLX , etc...) <b>or</b> the manufacturer of the entire system (Dell, HP, E-Machines, Sony...)
Mainboard
Manufacturer NEC COMPUTERS INTERNATIONAL
MP Support 1 CPU(s)
MPS Version 1.40
Model SiS651
Version 1.x
If that info's not right..could you tell me where to go to find the right infomation please
Powermate ML4...
It may be one this one...
<b>PowerMate ML4 Convertible - SIS 650 / 651 Chipset</b>
CPU Socket 478B
Supports Intel P4 FC-PGA2 (Flip-Chip Pin Grid Array), 1400 MHz to 2.6 GHz
Chipset SIS 650 / 651 depending on the model
On-board graphics.
Soft audio onboard STAC9756T(Direct sound AC97 2.2 audio).
If so.... go to NEC's Support Page
Click on Desktop, then look for the model that looks like your PC... then click download and select the drivers for the motherboard and the sound...
http://support.packardbell.com/uk/mypc/index.php?PibItemNr=platform_clipper_imediavl&PibLinkGroup=2000#show
If you'd like, PM the serial number and I can take a look at what you need to download... up to you.
Sparky
Here are my specs:
System Model ( mother board )
Enclosure Type: Desktop
Multimedia ( Sound card )
MPU-401 Compatible MIDI Device
Standard Game Port
Probably not detecting the onboard sound device
Main Circuit Board
Board: SiS-650
Bus Clock: 100 megahertz
BIOS: Award Software International, Inc. 6.00 PG 01/30/2002
Memory ( ram)
352 Megabytes Installed Memory
Slot 'A0' has 256 MB
Slot 'A1' has 128 MB
Slot 'A2' is Empty
Slot 'A3' is Empty
PLZ can anyone help me.
