Wireless connection between 2 pcs?
dodododo Landisville, PA
edited June 2004 in Nerdery
If you have 2 PCs running winxp, and both have wireless cards, do they automatically see one another and set up a network? What i mean is, is a WAP necessary? Somewhere i thought i heard this was possible, but i cant really test it right now.
~dodo
    edited June 2004
    It's called an AdHoc connection.
    I don't use AdHoc connections, so I don't know how to set one up, though presumably they would autoconfigure.
  • dodododo Landisville, PA
    edited June 2004
    sweet, thanks for the info. i just wanted to know if it was possible.
