ASUS P2B and Hard drive problem
Ok a little older school stuff. I have a ASUS P2B with a P2 400 cpu and i'm unable to get the my 15 gig Quantum hard drive to recognize in the bios. I have the jumper correct (master) The cable is plugged in correctly and have tried 3 different cables. I've updated the bios still no go. I know the HD works as my P4 will see it. I've tried 2 other Hard drives one being a maxtor 8 gig and the other being a maxtor 40 gig. They won't recognize either. Any help you guys could give my will be greatly accepted.
Thanks in advance
Fatman777 :banghead:
Thanks in advance
Thanks dude!!
Fatman
Try it with THE SAMEW CABLE in both ide connectors to see if its the cable or a ide channel prob.
Its usually a cable related prob. Either the cable wasn't pushe din good or its a bad cable etc..
Tex
