Options
HJT log, AIM .SCR problem, please help!!
Logfile of HijackThis v1.97.7
Scan saved at 4:52:04 PM, on 7/9/2004
Platform: Windows XP (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 (6.00.2600.0000)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\D-Tools\daemon.exe
C:\Program Files\SysMetrix\SysMetrix.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\System32\ulwjwbxj.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\AIM\aim.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\HistoryKill\hkPopupKiller.exe
C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\Program Files\Ares\Ares.exe
C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe
C:\PROGRA~1\HEWLET~1\HPSHAR~1\hpgs2wnf.exe
C:\WINDOWS\SYSTEM32\MSGinaV.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Documents and Settings\Ozymandias\Local Settings\Temporary Internet Files\Content.IE5\OXMJGTAV\HijackThis[1].exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = about:blank
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://best-search.cc/index.php?v=6&aff=4749070
R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = about:blank
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *hot-searches.com*;*lender-search.com*
O1 - Hosts file is located at: C:\WINDOWS\nsdb\hosts
O1 - Hosts: 81.211.105.69 lender-search.com
O1 - Hosts: 81.211.105.68 hot-searches.com
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [DAEMON Tools-1033] "C:\Program Files\D-Tools\daemon.exe" -lang 1033
O4 - HKLM\..\Run: [DeadAIM] rundll32.exe "C:\PROGRA~1\AIM\\DeadAIM.ocm",ExportedCheckODLs
O4 - HKLM\..\Run: [SysMetrix] C:\Program Files\SysMetrix\SysMetrix.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE NvQTwk,NvCplDaemon initialize
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [zrxrfvhyvt] C:\WINDOWS\System32\ulwjwbxj.exe
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [Microsoft Gina V Encryption] MSGINAV.EXE
O4 - HKCU\..\Run: [AIM] C:\Program Files\AIM\aim.exe -cnetwait.odl
O4 - HKCU\..\Run: [HistoryKill] C:\Program Files\HistoryKill\histkill.exe /startup
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKLM\..\RunOnce: [GrpConv] grpconv.exe -o
O4 - HKLM\..\RunOnce: [AiOInstInstall] C:\WINDOWS\System32\hpocon09.exe /p "192.168.0.2" /n "hp officejet g series" /f "hp officejet g series fax" /k "1" /i "C:\WINDOWS\INF\oem7.inf"
O4 - HKCU\..\RunOnce: [Microsoft Gina V Encryption] MSGINAV.EXE
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: AIM (HKLM)
O9 - Extra button: Related (HKLM)
O9 - Extra 'Tools' menuitem: Show &Related Links (HKLM)
O9 - Extra button: Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Windows Messenger (HKLM)
O16 - DPF: {10000000-1000-0000-1000-000000000000} - file://C:\Program Files\Internet Explorer\setup.exe
O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} - http://download.microsoft.com/download/F/6/E/F6E491A6-77E1-4E20-9F5F-94901338C922/wmv9VCM.CAB
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} (FilePlanet Download Control Class) - http://www.fileplanet.com/fpdlmgr/cabs/FPDC_1_0_0_42.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
I'm wondering 1) which file is the file that I need to delete to get rid of the new ' Look! ' then URL thingy that changes ur away msg and brings up about an add every minute or so, AND If I do have any other adware/spyware, can you please tell me what it is?
Thank you so much
-Ozy...
PS: I think it'd be faster to just e-mail me, I rarely check ANY of the forums that i belong to... desiozymandias@gmail.com
Thanks again
Running processes:
Thank you so much
-Ozy...
Thanks again
you've got several problems there.
please check out this post, and follow the instructions:
http://www.short-media.com/forum/showthread.php?t=14915
also, check out this post, should help remove the look! problem.
http://www.short-media.com/forum/showthread.php?t=15942
Thx,
Ozy
Please help X____X
Ozy
For the computer to be able to "see" the file, you must tell Windows to "Show hidden files and folders" in Windows Explorer.
To do this:
Hit the Start button, and select "Run".
Type "explorer" in the box, and hit Ok.
In the window that appears, select the Tools drop down menu, and then select "Folder Options".
Select the "View" tab, and check the box labeled "Show hidden files and folders".
Select Ok, and then close all the windows.
Now try to delete the file.
Logfile of HijackThis v1.98.0
Scan saved at 9:56:38 PM, on 7/13/2004
Running processes:
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\System32\MSGINAV.EXE
C:\Program Files\iTunes\iTunesHelper.exe
C:\WINDOWS\System32\rundll32.exe
C:\WINDOWS\System32\RUNDLL32.EXE
C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\Bin\hpoavn07.exe
C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\FRU\Remind32.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
C:\WINDOWS\System32\hpoinw07.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\PROGRA~1\HEWLET~1\AiO\Shared\Bin\hpoevm07.exe
C:\WINDOWS\System32\hpoipm07.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Norton AntiVirus\SAVScan.exe
C:\Program Files\Hewlett-Packard\AiO\Shared\bin\hpOSTS07.exe
C:\Program Files\Hewlett-Packard\AiO\Shared\bin\hpOFXM07.exe
C:\Program Files\Winamp\winamp.exe
C:\Documents and Settings\Ozymandias\My Documents\My Stuff\HijackThis.exe
F0 - system.ini: Shell=
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe,
O2 - BHO: (no name) - {0000607D-D204-42C7-8E46-216055BF9918} - (no file)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [SimpleBT] C:\Program Files\SimpleBT\SimpleBT.exe -tray
O4 - HKLM\..\Run: [Advanced Tools Check] C:\PROGRA~1\NORTON~1\AdvTools\ADVCHK.EXE
O4 - HKLM\..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe
O4 - HKCU\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NVMCTRAY.DLL,NvTaskbarInit
O4 - Startup: Hewlett-Packard Recorder.lnk = C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\FRU\Remind32.exe
O4 - Global Startup: HPAiODevice(hp officejet g series) - 1.lnk = C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\Bin\hpoavn07.exe
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O18 - Filter: text/html - {4F7681E5-6CAF-478D-9CB8-4CA593BEE7FB} - (no file)
Note: the msginav.exe is in the [Runonce] thing, now when I try to fix it:
Scan saved at 9:57:19 PM, on 7/13/2004
Running processes:
C:\WINDOWS\notepad.exe
It is under the normal [Run] section, and I have done your instructions a total of three times, and i found out that msginav.exe will change to a different extention (by adding stuff after the file name like -xxxxx.pf or such (that's what mine was like, it was a .pf) So if anyone is having trouble finding it, search for msginav and that's it....
Please see if you can help me
Thanks,
Ozy
Thx for all of your help though
-- Ozy
I've followed SmJ's removal guide a few times and it's allways coming back, and I've done everything the EXACT way he's said to do it...
I need help :-\
Please help
-- Ozy
