heat sink problem, question
ok , i just opened up my amd athlon 3000+. and i took out the heatsink, and theres this grey square of some type of puddy on it, i was wondering should i remove that, or leave it on, ...thanks...
, ill probably be getting a better heatsink anyways, like an slk-800 or 900
, ill probably be getting a better heatsink anyways, like an slk-800 or 900 0
If you took heatsink off of CPU in case, most of the proper heatsink compund is grayish these days, or whitish beige color. That should stay unless it is uneven and got wiped uneven while heatsink was being taken off. If that is the case, it gets verycarefully cleaned off and replaced with a tiny bit of heatsink compund-- something like Arctic Silver Ceramique would work, but only on the raised central CORE and not elsewhere on the chip.
thanks for ur help guys:)
The solder has micro-gaps.
The older CPUs came with a thermal tape pad (pinkish or pure white) which I usually took off VERY CAREFULLY and replaced with paste. Cooler with paste, I experimented both ways.
