Does a Sony CPD-G520 have a better picture quality than a Compaq P1100?
Or are they both about the same? I recently upgraded from a Sony E400 which was my most prized possession in the whole world to a Compaq P1100. I thought since the P1100 was based on the trinitron tubes it should be identical to a sony made monitor but the picture quality isn't as good or as sharp as my old E400.
I have a friend that would gladly buy the Compaq off me so i'm wondering if i should just try for a Sony CPD-G520 for a true upgrade to my E400. Is the P1100 just not quite as good as the sony made ones or could the fact that its refurbished likely have something to do with it? (i.e. would i likely be in the same boat had i bought a refurb G530?)
Thanks.
Thanks.
Even after numerous calibrations, text and colours just weren't as sharp or clear on the G520 as they are on my P1100. If you bought the P1100 from merkortech, it's unlikely that the monitor is suffering from anything more than a lack of proper calibration.
Try 90 or 100. If that doesn't work, than I'd say you're SOL.
