Need Help RIGHT AWAY! Monitor Problem
Ok i'm working on my mom's office computer and i go to visual settings and i saw that the option for 1600x1200 was available and i was surprised because it was only a 17" lcd. So i selected it and the monitor said that option was not available. I tried just restarting and it will show the windows splash screen and all that but when it comes to windows it just says "Mode not supported". There are no monitors in the office that could support that resolution at the moment so i'm basicly screwed unless someone has some awesome idea on how to "reset cmos" of the monitor
.:banghead: :banghead: :banghead:
Specs:
Celeron 2.6
512 pc2100
Intel Extreme Graphics
MAG 17" LCD
WinXp Pro Corp
.:banghead: :banghead: :banghead:Specs:
Celeron 2.6
512 pc2100
MAG 17" LCD
WinXp Pro Corp
OR
2) Find a monitor that supports 1600x1200, plug it in, then reset your resolution back down to what it was. Return the correct monitor.
Maybe catch me on AIM a little later tonight if those don't work...
It's on the list.
Good Luck!
Prof
let us know when you get it.
That "press the F8" biz seems to be very MB dependant.
I usually just hit the sucker like a big dog, and ignore any KB errors that come along.
Plus: I buy new Keyboards frequently...;D
Prof
NS
