Geforce 5700 fx ultra and KT800 Problem
Hey i Recently jus upgraded to a Soyo Kt800 Dragon 2 and i got everything put in good...and i jus started up my system and it ran good... I started to install games... I ran UT 2k4 and it was weird like the movies
were like polygons and shapes and stuff. So i tried Call of duty and it acted very weird like flashed lines when i moved my cursor.
So at first i thought bout different drivers so i switched to the omegas and uninstalled the nvidias. Still have the prob. I had jus recently
installed Windows Xp pro sp2 right BEFORE gettin new mobo. Should i reinstall os again? Or is there any other ideas. All i upgraded was the mobo and another 512 of ram. My vid Card is the Asylum 5700 ultra.. and everything worked completely fine in my old asus mobo. Thanks for any help.
when i change motherboards i usually reinstall windows... if you dont have too much stuff on there, you could try a fresh install of windows.
