Can someone help with a home network problem?
I'm trying to home network a winxp and win98 machine using the factory cards. Intel pro100 in the xp and davicom in the 98. I got both cards setup but I get the error on the xp machine that the cable is unplugged, which it's not, I have both computers directly connected by one cable. That should work right? Any ideas about this error? I've gone through the process a dozen times. Seems that if both cards are recognized on their respective computers there is not much, hardware speaking, that could fail right?
Thanks and have a great weekend
Thanks
You have to make sure they are in the same workgroup.
First, find out the IP of each machine and then we can help you diagnose the problem.
To find out the IP, go to a command prompt (Start --> Run --> type "command" on the 98 box) (start-->run--> type "cmd" on the XP box)
Then at the command prompt type "IPCONFIG /ALL"
That will tell you the address of each one.
Find out, and post them here.
IPCONFIG /ALL
You don't enter the addresses anywhere - they are ASSIGNED by the router.
IPCONFIG /ALL
you get nothing?
How about just IPCONFIG
on the xp box. goto the run box and enter services.msc
now enable dhcp client service, dns client, network location awareness service, and network connections.
make sure that the card is install properly in device manager as well...
g
