Questions on water cooling
My XP3200 runs hot, I'm using a Thermalright SLK-800 with a Pabst medium flo fan & Arctic Silver 5 but it's still hitting 61C on full load even with the case side off. Room temps are quite warm. I can't mount a bolt through cooler as this Gigabyte board has no mounting holes.
I discussed this problem with jimborae and others elsewhere, and he recommended the following kit. I have a coupla questions to ask (they're after the pix).
Here's pix of the kit jimborae recommended, I've decided to go with it, though still not entirely sure about the pump:
I can mount the pump on the floor of the case; remove the rear exhausting 80mm case fan and fit the radiator there, and I'll have to mount the reservoir externally, probably on the wall on a lift off bracket. I can probably also lose my 80mm case roof fan, leaving just the two x Vantec stealths at the front of the case cooling the pair of Raptors.
That means quiet
My questions are: I notice all components have half inch fittings except the reservoir, whic has 10mm fittings. Now, do they mean the internal diameter of the tubing is 10mm and the half inch (12.5mm) tubing will fit as it's external diameter is half inch? Or will I need a couple of adaptors to fit half inch tubing to reservoir?
Also, how do I top the reservoir up? Does it have a filler plug at the top or something?
Is it worth adding any of that anti-fungi/algae additive?
And lastly, is it worth fitting a quiet 120mm fan to the radiator? I think it is, but the blurb on the reservoir says that because of it's design it can enable a system to run fanless.
Any comments/advice gratefully apreciated, as I'm a little nervous about this.
That means quiet
I have actually adivised to fit a fan to the rad as this will provide the main cooling despite the res manufacture's claims. Also bear in mind that quiet cooling at a decent price is the main aim here not ludicrous overclocking hence the pump recommendation.
That way your system will be compleatly sealed.Once you get the water right it'll pretty much just keep on going.
I'm in the same boat as you sorta going water cooling for the first time. I know I've read time and time again thats the best Water block Bar none. I've been reading that the car heater coils are the best for rads.
This is a great place to read up on water cooling http://forums.extremeoverclocking.com/forumdisplay.php?f=181
Do you really need a reservoir? It doesn't help at all once the system is filled and if something, it makes the flow worse. Worse flow= Very often higher temperatures.
My suggestion is to save that money and buy a videocard waterblock instead.
Another thing to consider is what kind of tubing to use also. I'm using 1/2" silicone in my dually and I've read and also noticed that silicone "loses" volume easier than vinyl tubing, with the water molecules being easier to migrate through it I believe. Nothing that shows as condensation, but you do have to keep an eye on the water level every few months, especially if you go with no reservoir. It is superior to vinyl in kink resistance though. Another good choice for tubing is Eheim's tubing they use in their canister filters. It is a green tinted premium vinyl tubing and isn't as expensive as silicone or tygon, but hold up well. You should be able to find it at a pet shop or online pet supply store. I've heard that the tygon tubing is real good, but expensive, even more expensive than silicone.
