Please help me help my friend
Thanks for your help one year ago. Now my friend is wanting to build a computer. Money is kind of a problem. Here is what we come up with so far:
http://www.newegg.com/app/ViewProductDesc.asp?description=13-135-152&depa=1
Says - 2 USB 2.0 header support additional 4 USB
Ports. The pic shows 4 USB ports. What am I not
understanding?
Also, the Realtek ALC655 6-Channel Codec is not 5.1 is it? What is 6-channel codec?
http://www.newegg.com/app/viewproductdesc.asp?description=22-152-011&DEPA=1
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-122&depa=1
http://www.newegg.com/app/ViewProductDesc.asp?description=19-116-171&depa=1
http://www.newegg.com/app/viewproductdesc.asp?description=14-142-009&DEPA=1
http://www.newegg.com/app/ViewProductDesc.asp?description=27-106-934&depa=0
Thanks
understanding?
Thanks
Anyways, 6.0 audio codec is simply a fancier way of saying the onboard audio supports 5.1 surround computer speakers.
I hope that clarifies things a bit, I'd like to look at all the rest of the items you linked to but since I'm on dialup waiting for those links to open could very well take me another half hour.
verify the four back ports are usb 2.0. Sometimes they give you some of both so its possible the back ones are usb1.1 but I bet they are 2.0. Go download the manual and check it. If money is a problem why are getting a P4 instead of a AMD setup?
Tex
Just to be perfectly clear 6-channel sound means there exists the ability to feed six different signals.
Front Right
Front Left
Right Rear
Left Rear
LFE (sub)
Centre
It does not mean that you get 5.1 surround automatically with a DVD movie, for example, you will still need the software player to provide the decoding...but this is pretty common in DVD player software
It's the same thinking for 2-channel, 4-channel, 8-channel. Think of it as x number of separate pipes.
Tex, thanks for the further clarification. Too bad the ECS board doesn't come with a bundled in rear add-on header.
Not you of course.
Look in your manual for jumpers on socket pins or elsewhere on board that enable or disable one or more pairs of ports on motherboard for USB also. Cheaper boards can have one header used either\or so you might be limited to 6 ports active at any one time with a less expensive motherboard. I have run into this on ECS and MSI boards. lso see how many physical root hub USB controllers you have and see if Firewire and USB are run from one controller. I have seen boards that let you use less for USB if you use Firewire actively, also.
8 Ports might be a theoretical number for the board you are thinking of buying, that is not achievable in reality. I have seen boards with two physical SERIAL bus controllers (not COM 9-pin serial, talking Firewire and USB still) which will let you have the following:
2 Firewire and 6 USB ports active at once max, OR 8 USB only ports active max. And have seen some where you get loss of two ports on back to get two active on front. The value is partly in the fine details.
