sound and audio devices
Had some viruses on my pc and lost sound. cant reinstall for some reason. Had SoundMax onboard audio sys. I have allready reloaded windows and changed hard drives and still cant get sound. Any suggestions? Is there a web site that i can download an Audio sys. from cheap?
BTW, is this onboard sound or PCI card, if it's onboard make certain it's enabled in the bios and if it's PCI power down your system, unplug the PSU and try reseating the card, it might have shifted in the PCI slot.
OR
u make sure the sound card is detected in the pci slot.simply take it out and rub the gold fingers of the card by rubber then slot it in again. if don't work, change to other pci slot.finally go to device manager and right click the sound device then select uninstall, go to windows>inf>other delete all the files(it's Safe). reboot the pc, then run setup.try and see does this work. if don't email me. i will help u.
