Problem with disconnecting my nomad zen
edited October 2004 in Software
:banghead: I have a nomad zen 20 gig. I have a problem with disconnecting it from my computer. the thing is there's no icon shown so I can safely disconnect it. is there a way I can shut it down before I plug it out? last time I plugged it out without shutting it down, I had to reset the damn thing.
  • MountainDewMountainDew Kentwood, MI
    edited October 2004
    i have a zen xtra 30gb, from what ive seen theres no way to turn off the zen while its connected to your computer unless you wait for the power-saving feature to turn it off.
    i have no problems when ust unplugging it, maybe you should try upgrading you nomad's OS, you can get it at creative's site.
