ATI Radeon 9800 Pro problem!
Hi, my pc is only a week old. P4 3.0ghz, 512mb ram, and my gfx card is the 128mb ati radeon 9800 pro aiw.
Today, seemingly (but not 100%) after installing an automatic update from windows (service pack 2) my pc was rebooting, and it gave me an ati restore error and restarted. It got to desktop and completely froze, rebooted again, and one of those blackout things occured where the signal seems to stop and monitor turns off.
The only way I can get my pc to start now is to load safe mode, and uninstall the display drivers for the gfx card, then start windows normally...thats what im doing now. Only problem is because I dont have any drivers on I cant play games, and everything scrolls slow etc (you know what I mean). If I use my msi ati driver cd and install a driver, after restart the same problem happens, blackout, freeze or complete crash. I tried cat 4.9 as well and the same thing. Basically I cant install any drivers.
Does anyone know what I could do, or have any recommendations?
Thanks in advance
Thanks in advance
Ok.. first stop.. uninstall the catalysts...
Run driver cleaner 3 to clear out any last lurking ATI gunk..
http://www.driverheaven.net/cleaner/
Then reinstall Direct X9 (get it from the microsoft website)
Reboot.. and install the latest normal catalysts from the ATI site
Rebooted, got an error saying "failed to initialise" followed by some hex, seems in reference to cat. Also got a VPU recover error, telling me it reset my graphics accelerator as it was no longer responding to graphics driver commands.
Oh dear...
If that doesn't solve it.. Id say.. try a reinstall of Windows clean w/sp2 BEFORE installing a new Direct X & catalysts.
If that fails, I think you have a dud card.
You got time & energy to wipe it clean and reinstall Windows? If its only a week old..
The fact that it happened right after I installed windows sp2 makes it seem as though its something to do with that, especially as I read somewhere that sp2 overwrites newer cab files with its own ones etc, but thats why I thought driver/cab cleaner would work.
But still it doesnt seem like it could be hardware, at least I hope its not. Thanks for all your help, I'll let you know what happens.
Thanks once again for your help mate, twas much appreciated fella.
Top class mate.. top class
If you want to run SP2 that is...
Good to hear you are running ok now..
I just recentally reinstalled my OS and I would like to get SP2 installed ASAP.
