Old drive failed, new drive problem system un-usable!
edited October 2004 in Hardware
Hi,
I have a major problem, the primary boot drive on my PC has failed, I got a replacement drive immediatly, the replacement is a SATA Maxtor MaxLine III 300gb and it is not been detected therefore i cant use my PC.
My motherboard is a GA-7N400 Pro Bios version F17, I have tried switching cables etc and it is not been detected at all(and is not even spinning up correctly).
It IS been detected if i plug the datacable into the drive AFTER it has spun up(yes it spins up without a problem when datacable not plugged in) but this is obviously not maintainable. I desperatly need to know if there is a way to fix this problem, or if this is a fault related to the Drive or a Motherboard issue with the Drive since i need the computer for work purposes. :bawling:
    edited October 2004
    Have you tried the other SATA port on the motherboard? I mean, it's either the controller, the individual port, or the drive. So eliminate the port first. Was your old drive IDE or SATA?
  • edited October 2004
    I have tried both ports on the motherboard, my other drive was not SATA, the storage drive on the system is SATA and that is working fine(on both ports).
    edited October 2004
    Well then it's the drive.... If you've eliminated the possibility that it's the cable, the controller, or the ports..
    Oh no! I would just use the Storage Drive as the boot except its near enuff full!
    Could it be an issue with the SATA since the drive is SATA-2 and the motherboard isnt exactly new?
    edited October 2004
    It could be one of two things:
    Either the drive is not compatible with the board or the drive is bad.
    I lean towards "bad drive" because if it spins up and detects after you boot, then it's obvious that it is at least somewhat compatible with your mobo.
    I was fearing that, it is detecting once it has spun up but will only spin up without the cable plugged into the board which is why i was hoping it could be a motherboard problem.
    Proberly should fill out a returns request thing and send it back?
    edited October 2004
    sounds like it :(
    oh well thanks for all your help :thumbsup::) , any idea how good Maxtor are at getting drives back to you after repairs? :(
    edited October 2004
    Really good, but it takes a couple of weeks...
    oh dear, i'm going to have to rustle up a drive in the mean time from someware *looks around work*
