Need help overclocking a 9700 Pro!
First of all, I have no cooling on the memory and the stock cooler on the gpu, but this is just rediculous.
I just started trying to overclock this to possibly break 2000 on 3DMark '05.
Downloaded ATiTool:
Memory sees artifacts just above stock, like 312 MHz or so.
Core gets artifacts at ~332
Stock speeds are 325/310
So... WTF?!
I think Asus probe is getting MB temp wrong because I have 2 intake fans in an air conditioned room. It reports 95*F. (35*C)
What rail is responsible for video cards? I think it's either the 3.3v or 5v rail right?? Is +3.15 - 3.2v good for the 3.3v? 5v rail reads 5.16.
Any suggestions? I think something's wrong here because I never get artifacts while gaming and ati tool gets them just above normal speeds. :bawling:
Downloaded ATiTool:
So... WTF?!
Second, I don't know why it has such low tolerance levels. I don't know much about 9700 pros ... maybe it's either just a weak core, or the entire 9700 line of cores are that poor. Maybe someone else could help here ... ?
Last, I wouldn't worry about overclocking your video card. I did. Even my crappy r350 core could [barely] pull XT speeds. Guess how much performance increase I noticed? If I didn't have ATiTool and it's little graph thing ... I wouldn't of known. It produced slight instabilities with the card. And maybe 1 FPS. So, unless you can achieve MASSIVE (40 or 50 mhz) overclocks, don't bother. It's unneeded stress on the card. Hope that helps some, even if it wasn't what you wanted to here
but, it's watercooled. before watercooling, it would barely overclock any.
I need a newer video card.
