Finally got the sound on the VA-10 working at a decent level but it is still very quiet through headphones. SOunds great, just quiet. What settings should I look for that would not be maxed out by default?
hmm, i just checked out the headphones specs, the Impedance is only 32 ohms, which if not all, then most protable players can even drive them, your onboard sounds should be able to as well.
it could be just that the onboard sound isn't able to drive the headphone u have hooked up to the onboard sound.
