XP SP2 Wireless Problems
edited November 2004 in Science & Tech
Ever since installing SP2 I've had all sorts of grief with my wireless connections, particularly when using VPN. The vpn connection randomly drops and the signal stregth of the WLAN frequently goes from 100% to 0%.
I have a Linksys wireless b router but don't think it's the problem..I have a non SP2 machine that has no trouble connecting. My laptop is an IBM T41 w/ an Intel 2100 wireless adapter.
Does anyone know of a solution?
Thanks!
  • pokesquid808pokesquid808 SO CAL
    have the same laptop....uninstall sp2. for some reason it just doesn't like it. one thing i dind't try is the intel client. it could be ibm all access that is causing the issue. i haven't had time to play with that. i knwo you can download the intel client from their site.
