Problem loading discs please help!
First post...big problem.
I was trying to copy a cd for a friend, using RecordNow and the disc was not big enough or something. Anyway, I canceled the programe and went to load a cd, just to listen to. I put the cd in and it seems like it is loading (green light flashing and a few noises) but the cd never loaded. The I tried another cd, not working. The I tried a disc of a programe, WOULD NOT LOAD. I hit start, then run, then looked in the D drive and nothin was there!
Please help! The PC is new enough and I dont own it and I will be in trouble if this does not get working!!
Have you tried rebooting the computer?
well i restarted my pc and it still is not working. I checked my computer and the cd-rom drive icon is there...so you said it is probably a break down. what exactly does this mean.
note: i dont think it needs to be cleaned the pc is only about 4 weeks old.
