help
robgunnerrobgunner Far away from anywhere
edited December 2004 in Spyware & Virus Removal
i keep getting grey tool bar appear when load up internet explorer,cant close ,when right click on bar click properties it says mysearchnow.com,run spy bot which did not work,run ad-aware and norton antivirus and also run hijack this andLogfile of HijackThis v1.98.2
Scan saved at 12:33:49, on 18/12/2004
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
C:\Program Files\Norton AntiVirus\SAVScan.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
C:\Program Files\Gigabyte\Gigabyte Windows Utility Manager\ET4\et4Tray.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I0H2.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Messenger Plus! 3\MsgPlus.exe
C:\Program Files\QuickTime\qttask.exe
C:\WINDOWS\system32\rundll32.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
D:\My Received Files\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.bnpuqymukcnxvjhjetux.com/zR0pWCXHd2Z7juKGSV3OhF7pNbMJqgwO6l7cTj/DY_JJ9LpFkt46wDENqcTJ_tbX.asp
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [EasyTuneIV] C:\Program Files\Gigabyte\Gigabyte Windows Utility Manager\ET4\et4Tray.exe
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [EPSON Stylus Photo R200 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I0H2.EXE /P30 "EPSON Stylus Photo R200 Series" /O6 "USB001" /M "Stylus Photo R200"
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [Advanced Tools Check] C:\PROGRA~1\NORTON~1\AdvTools\ADVCHK.EXE
O4 - HKLM\..\Run: [MessengerPlus3] "C:\Program Files\Messenger Plus! 3\MsgPlus.exe"
O4 - HKLM\..\Run: [JumpChicTonsTest] C:\Documents and Settings\All Users\Application Data\idle stop jump chic\drive shim.exe
O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [MessengerPlus3] "C:\Program Files\Messenger Plus! 3\MsgPlus.exe" /WinStart
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O8 - Extra context menu item: E&xport to Microsoft Office Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O17 - HKLM\System\CCS\Services\Tcpip\..\{C0E280D1-9746-4643-99FE-F15695922739}: NameServer = 192.168.0.1
could some one please help im going crazy
  • CrunchieCrunchie Mandurah. Western Australia. Member
    Hi. First of all you need to update hijackthis to version 1.99. Run hijackthis & go to *Config\Misc Tools\Check for update on-line*. If the site is down, go here. Remove the old version by opening the program, going to config\misc tools, then uninstall & exit. You then have to delete the file manually. Unzip the new version into the hijackthis folder.
    Click Start>Settings>Control Panel>Add or Remove Programs and uninstall 'Window Search', 'Window Searching', 'Lop.com', 'LOP SEARCH', 'Browser Enhancer', or 'Ultimate Browser Enhancer' if listed. You may be given a code to insert, do so and reboot when done. If not listed there, run this uninstaller:
    http://members.rogers.com/rjmac/new_uninstall.exe
    Uninstall Messenger Plus as it comes bundled with LOP, the infection you currently enjoy :). You can reinstall Messenger Plus without the sponsor.
    Scan with hijackthis and tick the boxes next to all the following entries, then close all browser and explorer windows, and hit the "Fix checked" button.
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.bnpuqymukcnxvjhjetux.com...DENqcTJ_tbX.asp
    Reboot into safe mode by tapping f8 whilst starting your PC and delete the C:\Documents and Settings\All Users\Application Data\idle stop jump chic<----folder.
    Hidden folders will need to be shown.
    Reboot normally after doing the above, rescan with hijackthis, then post that log here please.
  • robgunnerrobgunner Far away from anywhere
    hello,thanks for all ur help the bar has now gone yippee
    thanks robgunner :)Logfile of HijackThis v1.99.0
    Scan saved at 14:41:55, on 18/12/2004
    Running processes:
    C:\Documents and Settings\Robgunner01\Desktop\hijackthis\HijackThis.exe
    O23 - Service: Ati HotKey Poller - Unknown - C:\WINDOWS\system32\Ati2evxx.exe
    O23 - Service: ATI Smart - Unknown - C:\WINDOWS\system32\ati2sgag.exe
    O23 - Service: Symantec Event Manager - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    O23 - Service: Symantec Password Validation - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
    O23 - Service: Symantec Settings Manager - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    O23 - Service: Norton AntiVirus Auto Protect Service - Symantec Corporation - C:\Program Files\Norton AntiVirus\navapsvc.exe
    O23 - Service: Norton Unerase Protection - Symantec Corporation - C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
    O23 - Service: SAVScan - Symantec Corporation - C:\Program Files\Norton AntiVirus\SAVScan.exe
    O23 - Service: ScriptBlocking Service - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
    O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    O23 - Service: SymWMI Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
    thanks again
  • SpywareShooterSpywareShooter 127.0.0.1
    Your log looks okay now. Are you still having any problems?
    no bars gone and no probs
    thanks for ur time and effort
    robgunner
