Help
I recently upgraded to win xp 64-bit but because there doesn´t seem to be any drivers that work to make my sound work I would like to uninstall it and return to 32-bit xp.
BIG question HOW?
I´ve tried to boot with the 32-bit CD in the optical drive only thing that happens is when the text "to boot from CD press any key" and I press a key the text returns and so on (just repeats everything).
I haven´t found any bootdisks for the 64-bit xp edition (beta).
So what can I do.
My system:
Asrock k8 upgrade 760-gx
AMD 64 3000+
512 RAM
Maxtor .... 200gig
Radeon 9250SE 128 mb
BIG question HOW?
So what can I do.
My system:
AMD 64 3000+
512 RAM
Maxtor .... 200gig
Is your CD drive set as the master on whichever IDE channel it's on? Some systems won't boot from a slave drive. You could also set the cd drive as first boot device and set all the other boot options to "None".
Hope this helps.
