Gigabyte GA-7n400-Pro 2 - RAID 0 Problems - Wont boot - urgent help required
Hi Guys,
I have a computer with the above motherboard, silicon raid chipset of course (crap)
I have two 80 gig HDD's SATA.
Raid was working fine, however the computer all of a sudden stopped booting
I then deleted the raid 0 set, and re-built the raid 0 set, which has now made things worse, as it does not even get to the xp screen with an error or anything, it just says insert book disk etc (of course meaning it cant find a valid boot device, my HDD's)
It is finding the HDD's and the raid set ok at boot
Things i have done:
Attempted to get into repair console on xp pro boot cd, gets in ok with the correct si3112 driver loaded on boot, gets to a C:\ prompt but says "invalid path specified"
I have changed to a D:\ prompt and ran "fixmbr" that didnt work either
i have tried deleting the raid set and re-building it various times
i have tried deleted the raid set altogether and trying it as one HDD without any luck
Please please please will someone help me out asap
thanks
Things i have done:
thanks
If that's corrupted, it wouldn't boot. I'm assuming you're using Win XP.
If you've rebuilt the RAID set, it's likely you've completely fubared any OS install.
I've never suffered a crash with Win XP, touch wood, but I've attempted to fix a few friends' crashed XP systems, all unsuccesfully.
It looks as though you'll have to do a fresh install.
You tried to boot from just one of the RAID 0 disks? Now, that really isn't going to work, is it?
anyone else have any other responses, especially as into any other way restoring the MBR or any data???
this is really urgent
thanks
I run this board,I like it.....anyhow
Since you have deleted the raid set the metadata has changed on the drives which is why it wont boot to OS
The only option you have now is to reinstall windows from scratch,in the future never delete a raid set until absolutely necessary,unless the data is vital I would consider it gone as it would not be possible to recover all of it.....
To be honest I am not sure
