Water!
My apartment has a sprinkler system so I am worried about my **** getting F*CKED UP! like really bad. I don't trust water
ANyways my question is... even though all my stuff stays plugged in, I turn my PC and Monitor off when not in use, if by some chance of my amazing fate the sprinklers go off, while everything is shutdown, should my stuff be ok? As long as I dry it out before turning it back on?
When your computer's off, there's only a vague trickle of electricity (Less than the power of a hearing-aid battery), so you really don't have much to worry about.
To answer your q RWB: I would be very careful putting the system on for a long while if the sprinklers have drained it.
A few weeks ago, i totally soaked my 9700 Pro and i waited like 3 days before using it again.
