System will not pass POST
I was doing some work to our office's FTP & Admin server, adding a couple of extra hard drives for backup storage. Next thing I know, the video card died. I put in a temp video card, and then got a new one today, installed it, and it worked fine.
When I rebooted the system, it would not POST. No beep, no OS boot. I tried turning it on and off a few times. Sometimes I would get the same problem, other times I would get continuos fast beeps, almost like a ringing telephone. I googled that but could not find anything.
I get no POST, no video output, no error message,, or sometimes I get the super fast beeping error.
I have:
-disconnected the new drives
- swapped back to the temp video card
- reseated RAM and CPU, heatsink, etc
- moved RAM to different slots
- checked all connections
I even tried removing the RAM and the video card, just to see if I get a different post error beep code, but nothing happens.
Motherboard is a Gigabyte 8IK1100.
Any ideas? Am I looking at a bad BIOS chip?
Thanks in advance.
Dexter...
I have:
Thanks in advance.
Dexter...
Try another stick of ram.
Dexter...
Dexter...
Third to that then the only culprit will be the motherboard.
The fact that you had the system up and running...and just added more drives then it wouldn't run anymore makes me think that the problem is motherboard related.
Because...going back to the working parts and after clearing BIOS and no post...leaves the likely culprit that the motherboard packed it in....the one way to confirm this is to double check the ram and video card in another system to make sure they are working...and then try the alleged faulty motherboard with another PSU....just to make sure the PSU didn't pack it in.
