DFI Lanparty NF4/3 sound issue SPDIF 5.1?
I have both a DFI Lanpart UT NF3 250GB and a NF4 Ultra-D. Both boards seem to only output two channel stereo sound to my Logitech Z-680 speaker system via the digital coax output (spdif). They both have onboard Realtek ALC850 7.1 channel audio.
On my a7n8x-e with NF2 soundstorm, I used to connect via digital coax, and get digital surround output, where it is in turn, decoded by the Z-680's onboard decoder.
As it stands now, I have to use the direct 6-ch analog minijacks for surround sound.
I have tried the following:
Realtek ALC850 drivers
Nvidia codec
Setting speaker config in ALC850 or Nvidia mixer
Setting 5.1 speaker config in Windows control panel
Tried setting the jumper (NF4) to switch spdif from nvidia chipset to alc850 karajan audio module.
Still only getting stereo output from the SPDIF out. I asked around on DFI street, but nobody seemed to have an answer for me. I'm wondering if this is just an ALC850 chipset limitation, or a simple driver/software/bios issue of some kind?
If anyone has any other ideas that they could share, it'd be really appreciated
Thanks
Nvidia codec
Thanks
Only the SoundStorm NF2 did this, it was (sadly) discontinued afterwards.
Not even the most expensive Creative Labs sound card will encode DDL and give you 5.1 over optical or coax digital. You can get 5.1 but the source has to be already ENCODED (ie. a DVD movie). If your source (for instance Winamp) is not DDL encoded, you will not get any more than 2 channels.
One of the (only? few?) cards that will do DDL encoding is the HDA X-Mystique 7.1.
Oh how I miss the MCP-T. Nvidia should have kept it alive. I posted this back in February, and I've learned to live with the analog 5.1. The sound is not quite as good as my NF2, but it's still quite good
Have you tried not installing the Realtek drivers and just use the NF drivers? I have not used the SPDIF but in my 5.1 set-up I can tell a difference in favor of just using the NF drivers.
I really must reccomend the HDA X-Mystique. It's a great card and it's nice to have something other than Creative.
Yeah I tried the realtek drivers when I first got it. Was not impressed
I kept hearing mixed reports from nvidia about soundstorm 2. Never really happened, I suppose it's off the drawing board now
Cool, I'll have to check that one out. I've never been a big fan of creative cards to be honest. I found their software side of things to be weak. Driver quirks and the like..
Most of the onboard sound is quite decent now-a-days. Maybe someday I'll spring for something better.
