Major issues with pci sound
Ok upgraded to a DFI Lanparty NF3 and tried to install my m-audio revo 5.1 cant get it to work right. IT comes up with an ! on it in the device manager saying it cannot start. So i try diff pci slot same issue. Do another fresh install of Xp, Same problem, Install a Phillips acoustic edge, Same issue. WTF is going on? BOTH of these cards worked on my last mobo
DFi Lanparty NF3
AMD 3400+
1 gig kingston 3700
gigabyte 6800
DFi Lanparty NF3
AMD 3400+
1 gig kingston 3700
gigabyte 6800
When i try to install the drives with the audigy i get a BSOD with IRQ not less or equal
As for your sound not going through all the speakers, check the settings on it (the onboard sound). Is it a Realtek Audio? If so, you may have a little icon in the bottom-right corner of the desktop that should let you adjust the sound settings.
IT finds it installs it and says " device cannot start up "
