Power Problem Battery vs Mains
Got a Dell Latitude CPi D233ST laptop.
I had it working fine two days ago. Then yesterday morning it would not boot.
Tried different things. Turns out that it works fine when on battery power and NOT connect to the Power supply. As soon as I connect it the computer goes blank. I mean Blank no warning, No shutting down - just goes off.
Thought that I have a short in the power supply, but have tried 2 others that i know work - same thing, as well as trying my power supply on anothe laptop - works fine.
Any surgestions?
Any surgestions?
If your laptop is under warranty it sounds like it's time to send it to the manufacturer. If not, any decent computer shop should be able to fix it.
The connector is soldered directly onto the motherboard. It has a fairly solid bracket, but would you surgest that I resolder the points?
Why does it shut down. with loose solder (dry solder points) i would think that all it did was not run the computer from the PS nor recharge the battery.
As far as resoldering, if you are experienced at doing that it is worth a try. Don't do anything to jeopardize any possible warranty you might have, though.
I am only suggesting that this is the most likely cause of the problem, there are certainly lots of other things it could be. The fact that it does the same thing with two other power supplies indicates that it must be something inside the laptop causing the problem.
As far as the other possibilities, you might try fooling around with (or even temporarily disabling) any energy conservation programs running in the background. If there is a problem in that area it might be sending the wrong command to the system, i.e. panicking and thinking it's out of juice when it actually has plenty.
It could also be that the relay that does the automatic switching between Battery and Mains is not working right and when it tries to switch over it hangs in the middle - leaving you with neither power source.
Thanks for the explanation.
I'm fairly verses in taking these laptops apart and doing soldering.
Aint got no warenty - unit is 4 1/2 years old.
Is difinetly sounds like it's worth a try.
because if it is the relay on the motherboard, then i'm f****
