help! major problems
Hi there - big problems here - please help!
my pc is playing up, i cannot access my history in internet expolrer, nor can i access my add and remove programmes either. My homepage is now 'about blank'
i have run both search adn destroy and adware, both found things and successfully deleted them
i have tried to runa hijack this log, but my pc will not let me.
i am a complete novice so please go easy
  • Buckeye_SamBuckeye_Sam Columbus, Ohio
    edited March 2005
    Ok, let's try to get a Hijackthis log in Safe Mode.
    Reboot your computer into Safe Mode
    See if you can get Hijackthis to run for you while in Safe Mode. Save the log, reboot back to normal mode and post it as a reply to this message.
  • edited March 2005
    Logfile of HijackThis v1.98.2
    Scan saved at 19:22:16, on 3/8/2005
    Platform: Windows XP (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 (6.00.2600.0000)
    Running processes:
    C:\WINNT\System32\smss.exe
    C:\WINNT\system32\winlogon.exe
    C:\WINNT\system32\services.exe
    C:\WINNT\system32\lsass.exe
    C:\WINNT\system32\svchost.exe
    C:\WINNT\system32\userinit.exe
    C:\WINNT\Explorer.EXE
    C:\Documents and Settings\AMD\Desktop\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://g.msn.co.uk/0SEENGB/SAOS01
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.co.uk/
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
    O2 - BHO: Internet Explorer Web Content Guard - {1B77D30A-81C9-497A-8647-142F7511B1FB} - C:\WINNT\System32\PAL\KLP\ieguard.dll
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O4 - HKLM\..\Run: [Synchronization Manager] mobsync.exe /logon
    O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINNT\system32\NeroCheck.exe
    O4 - HKLM\..\Run: [msnappau] "C:\Program Files\MSN Apps\Updater\01.02.3000.1001\en-gb\msnappau.exe"
    O4 - HKLM\..\Run: [klp] C:\WINNT\System32\PAL\KLP\explorer.exe
    O4 - HKLM\..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe
    O4 - HKLM\..\Run: [iPodManager] C:\Program Files\iPod\bin\iPodManager.exe
    O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
    O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
    O4 - HKLM\..\Run: [PPPOEOE] winlite.exe
    O4 - HKLM\..\Run: [Media Pass] C:\Program Files\Media Pass\MediaPass.exe
    O4 - HKLM\..\RunServices: [PPPOEOE] winlite.exe
    O4 - HKCU\..\Run: [Spyware Doctor] "C:\Program Files\Spyware Doctor\spydoctor.exe" /Q
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - Global Startup: BTTray.lnk = ?
    O4 - Global Startup: Slim 3000 Monitor.lnk = ?
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1096923745233
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://www.pandasoftware.com/activescan/as5/asinst.cab
    O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/msnmessengersetupdownloader.cab
    edited March 2005
    Not much showing up in your log.
    If you can get into Add/Remove Programs in Safe mode remove this program.
    Media Pass
    Place a checkmark next to these entries, close all browsers and windows, and have HijackThis fix them by clicking Fix Checked:
    Then delete this folder.
    Check to see if you can reset your home page. Also try to get a hijackthis log from normal mode.
  • edited March 2005
    all seems ok now! bizarre!
    this look ok?
    thank you sooo much :)
    Scan saved at 20:07:57, on 3/8/2005
    Running processes:
    C:\WINNT\System32\svchost.exe
    C:\WINNT\system32\spoolsv.exe
    C:\WINNT\System32\winlite.exe
    C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe
    C:\Program Files\MD7466\ICON.EXE
    C:\PROGRA~1\WIDCOMM\BLUETO~1\BTSTAC~1.EXE
    C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
    C:\Program Files\Alwil Software\Avast4\ashServ.exe
    C:\WINNT\System32\PAL\KLP\svchost.exe
    C:\Program Files\iPod\bin\iPodService.exe
    C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
    C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
    C:\WINNT\System32\wuauclt.exe
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    edited March 2005
    Your log looks clean to me. You need to make sure to get Windows Updates. You're missing a bunch of them.
    Now that you are clean, please follow these simple steps in order to keep your computer clean and secure:
    1. Disable and Enable System Restore. - If you are using Windows ME or XP then you should disable and reenable system restore to make sure there are no infected files found in a restore point left over from what we have just cleaned.
      You can find instructions on how to enable and reenable system restore here:
      Managing Windows Millenium System Restore
      or
      Windows XP System Restore Guide
      Renable system restore with instructions from tutorial above
    2. Make your Internet Explorer more secure - This can be done by following these simple instructions:
      1. From within Internet Explorer click on the Tools menu and then click on Options.
      2. Click once on the Security tab
      3. Click once on the Internet icon so it becomes highlighted.
      4. Click once on the Custom Level button.
        1. Change the Download signed ActiveX controls to Prompt
        2. Change the Download unsigned ActiveX controls to Disable
        3. Change the Initialize and script ActiveX controls not marked as safe to Disable
        4. Change the Installation of desktop items to Prompt
        5. Change the Launching programs and files in an IFRAME to Prompt
        6. Change the Navigate sub-frames across different domains to Prompt
        7. When all these settings have been made, click on the OK button.
        8. If it prompts you as to whether or not you want to save the settings, press the Yes button.
      5. Next press the Apply button and then the OK to exit the Internet Properties page.
    3. Use an AntiVirus Software - It is very important that your computer has an anti-virus software running on your machine. This alone can save you a lot of trouble with malware in the future.
      See this link for a listing of some online & their stand-alone antivirus programs:
      Virus, Spyware, and Malware Protection and Removal Resources
    4. Update your AntiVirus Software - It is imperitive that you update your Antivirus software at least once a week (Even more if you wish). If you do not update your antivirus software then it will not be able to catch any of the new variants that may come out.
    5. Use a Firewall - I can not stress how important it is that you use a Firewall on your computer. Without a firewall your computer is succeptible to being hacked and taken over. I am very serious about this and see it happen almost every day with my clients. Simply using a Firewall in its default configuration can lower your risk greatly.
      For a tutorial on Firewalls and a listing of some available ones see the link below:
      Understanding and Using Firewalls
    6. Visit Microsoft's Windows Update Site Frequently - It is important that you visit http://www.windowsupdate.com regularly. This will ensure your computer has always the latest security updates available installed on your computer. If there are new updates to install, install them immediately, reboot your computer, and revisit the site until there are no more critical updates.
    7. Install Spybot - Search and Destroy - Install and download Spybot - Search and Destroy with its TeaTimer option. This will provide realtime spyware & hijacker protection on your computer alongside your virus protection. You should also scan your computer with program on a regular basis just as you would an antivirus software.
      A tutorial on installing & using this product can be found here:
      Using Spybot - Search & Destroy to remove Spyware , Malware, and Hijackers
    8. Install Ad-Aware - Install and download Ad-Aware. ou should also scan your computer with program on a regular basis just as you would an antivirus software in conjunction with Spybot.
      Using Ad-aware to remove Spyware, Malware, & Hijackers from Your Computer
    9. Install SpywareBlaster - SpywareBlaster will added a large list of programs and sites into your Internet Explorer settings that will protect you from running and downloading known malicious programs.
      Using SpywareBlaster to protect your computer from Spyware and Malware
    10. Update all these programs regularly - Make sure you update all the programs I have listed regularly. Without regular updates you WILL NOT be protected when new malicious programs are released.
    Follow this list and your potential for being infected again will reduce dramatically.
