Options
NEw PC made but need help on front panel audio
edited March 2005 in Hardware
I just made a new pc with the Sapronos case and the epox 8kda motherboard. I'm not sure how to plug these in It goes
1 2
Mic|GND
NC |+5v
Front Line out R |Rear line out FR
| Key
Front line out L | Rear Line out FL
it says the front panel phone jack should have "normal close" switch. with phones plugged in the front the rears will be disabled.
SETTINGS
Pines (5-6) and (9-10) (Front line out R Rear line out FR and Front line out L and Rear line out FL) SHORT (default): Only the onboard rear panel audio jack ca be used.
Pines (5-6) and (9-10) (Front line out R Rear line out FR and Front line out L and Rear line out FL)OPEN:Only front panel audio jack can be used.
I hope this is good info to help me with my situation. if not I will post more specific
