Hard Drive Problem
Hello All.
I have a problem I have not come across before, and have searched for the result but found nothing.
I have an 80GB hard drive as a system drive and everything runs fine.
Added a new 160GB hard drive as storage and the computer will not power up. The case fan spins once then the PC shuts down.
I remove the power connector from the second drive and everything is fine again
I have a 400w power supply
1.8ghz p4
9200se 128mb video card
2 x Optical drives
Thanks for any help offered.
*I have just realised I have posted in wrong section. Mods, please accept apologies*
1.8ghz p4
2 x Optical drives
Double check to ensure that the ribbon cable is orientated the correct way. Some cables do not have the little 'notches' to ensure they are put in the correct way, so they can be reversed easily. The red stripe on the cable should be orientated the same way as your 80GB drive.
It sounds like it could also be a 'master/slave' configuration problem. Are you putting this drive on the same cable as your 80GB drive? (since you have 2 optical drives, I assume you are).. If this is the case, you'll have to set your 160GB drive as a 'slave' device. There are little jumpers next to the IDE connection that will allow you to choose. If you have the model number of your drive, we can help you set that as well, as not all drives have the same jumper settings.
Good luck!
h--p://www.samsung.com/Products/HardDiskDrive/support/Download/userguide/usersguide_02.htm
I have also double checke the cable, mine have the little notches so they can only go in one way.
I took a 40GB slave out and tried it all with that back in and it works ok. I also tried setting the 160gb as a master and the same power down happened. I am really stumped!
Just another quick thought, what is your primary drive set to? Is it set to master or cable select?
The 80gb is set to master.
The power supply is an EZ-Cool ATX JSP
DC = +3.3vdc +5vdc -5v +12 -12vdc +5vsb PSon Com POK
Output = 26A 30A .05A 12A .08A 2.0A REMOTE RETURN PG
So +3.3vdc will have __ A(mps) associated with it. The amps/volts are what I want to see. Just like in my post above.
