Power Supply Help 101
I took out my old power supply.
Im about to put in my new one right now.
I have a switch that looks like this .... O |
And a red voltage thing
Which ones do I flip.
The red one is corrently flipped to the left.
And the O is pressed down.
I need help now cause Im installing it at this moment tHX!!!
If you are in the USA, the voltage selector should be 115/120v... If you're in europe, it should be 220.
All 115 volts here
strangely, we use 115 instead of 120 like the US. Close enough that it does not affect the electronics..
1. Is there a program to tell the specs of your power supply.
2. I went in bios and found AGP departure. Do I set this to 256mb for my card?
since my card is 256?
3. The fan is not that loud
Thxxxxxxxxxxxxxxxxxxxxxxxx
See LemonLime's post above.
AGP APERATURE....yes and that's assuming you have enough system RAM (EG: 512 MB or more) If you have less...128-256 MB only...then you may want to set it at 128.
