Need help on installing Radeon 9600 Pro on Dell 4600
I have Dell 4600, it comes with integrated video cards on the mother board, when I tried to install Radeon 9600 Pro to the AGP slot, it does not work, ater I have installed the CD and plugged in the Radeon video card, when I test to connect my 17" flat panel to both video slot on the back of computer, the screen is just completely black, does anyone know what the problem is? Thank you.
1. I disable the Intel(R) 82865G Graphics controller under the Display adaptor
2. I have downloaded Microsof .NET Framework and CATALYST Componenet(Display Driver,
CATALYST Control Center, WDM Integrated Driver - 32MB) from the following ati link:
https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&folderID=27
3. I was able to installed the .NET Framework with no problem (I have not insert the Radeon card)
4. When I tried to install the CATALYST Component, it shows that the no ATI componenet is found since I have not plug in the Radeon card yet.
5. I have turn off the computer and insert the Radeon card while make sure that Primary adaptor is set to AUTO under F2, but once I have restart my computer with Radeon card inserted, the screen just become completely black on either Video slot on the back of the computer.
Should I uninstall my intergrated graphic card or just disable it will be enough?
Thank you.
reboot and make sure the new card works(moniter connected to the on board still)
shut down then plug the moniter into the new card, restart see what happens
Intel Pentium 4 processors and Intel Xeon processors include write combining store buffers to improve performance by combining multiple writes to several cache lines. If a heavily repeated inner loop writes to more than four cache lines, a single-threaded application experiences performance degradation. IE blackscreen or monitor will shut down after 5 mins or so. Just something to try if nothing else works.
Ming
You can try disabling the write combining first, and if that doesn't work, then the hyperthreading.
Of course to get to write combing and turn it off you must have the onboard video enabled.
Here's how to get to the write combining--
Turn off the Enable Write Combining feature (Windows XP only)
1. Click Start, and then click Control Panel.
2. Click Appearance and Themes.
3. Click Display.
4. On the Settings tab, click Advanced, and then click the Troubleshoot tab.
5. Click to clear the Enable write combining check box.
6. Click OK, and then click OK again.
Disable onboard video.
Reboot with Radeon 9600 in AGP slot.
If that doesn't work---
Then you might try disabling hyperthreading. You have to do it in the BIOS area. You'll have to look for it, I'm not familiar with your system., so I can't walk you through that one. Just look for anything that refers to hyperthreading being enabled--and disable it, save settings and reboot with Radeon 9600 in AGP slot.
If these options don't work, you can just reverse the settings back without any damage done. Then Re Enable onboard video.
