help with 9800 pro! power supply issue?
Hi, Someone please help.I got a radeon 9800 pro like 5 months ago.all was well and all of the sudden i was getting corrupt graphics,(lines,dots,converging,) in games and in windows. I RMA'd the card and got the new one back and same problem. and sometimes when i reboot, red banner comes up ans says i have not connected my card to my power supply right and most times i doesnt do that at all, I have tried rolling back drivers, reseating the card,leaving side off and putting fan on it, and i was thinking maybe it is an insufficiant psu. what do you guys think, my specs are:
amd 64 3500 winchester
asus a8v deluxe
1024 corsair twin xms duall channel
radeon 9800 pro 128 mb
tsunami dream (plenty of fans)
74 gig 10,000 rpm raptor
120 gig 72,00 samsung
heres the kicker 400 watt COMP USA psu (you can smack me later)
but would the psu be causing the corruption, wouldnt it like crash or reboot randomly or something? any input would help before i RMA my second card.
asus a8v deluxe
That psu should last you a long time
Ive seen artifacts caused on 9800pros sevral times by not enough power.
The 'card not connected to powersupply' message leads me to believe it is a PSU issue as well. The Antec 550 is a nice PSU, hopefully it'll correct your issues. What are your voltage readings btw? If you are spiking or sagging a lot, this can be a cause. You should be able to see your voltages in the bios. If the voltages are indeed off by any large margin, I would advise keeping the PC turned off unless absolutely necessary to prevent any damage.
+12v=12.096~12.16
+5v=4.972~4.99
+3.3v=3.296~3.312
vcore=1.422~1.406
this is after watching for about 5 minutes,do i need to watch longer,under load,and how do i check it under full load?
You can find prime 95 here.
There is still the possibility that you have another bad radeon. Do you have another PC or a friend's machine you can try the card out in?
Amperage (current draw) is equally (if not more) important than voltage. Your PSU could be supplying the right voltage, but if the amp draw is more than it can handle you are sunk.
Shut the computer down, open the case, then look on the PSU for a label listing the amperage of each rail.
5V+ = ~40A
12V+ = ~18A
3.3V+ - ~20A
+12v=18.0A
+5v=36.0A
+3.3v=22.0A
is this bad or does that sound like that could be my problem? or is this decent?
Your numbers don't look too bad, but one thing to keep in mind is that some manufacturers are notorious for being wildly optimistic about what their PSU's can actually produce.
More on that can be found here.
What is the brand of your PSU? The reason you'll see so many members stressing the importance of getting a good name brand is explained by the link above. The brands that get recommended are the ones who are known for delivering what they promise.
Do you have a friend with a spare PSU who would let you borrow it to test things out?
Finally, dumb question time, but you did plug in a power lead to the card, right? The error message you're getting is what makes me ask. It can be an easy thing to overlook, even for an old pro.
Be sure and let us know.
