Need Help Getting Radeon 9800 pro to work
I have a HP pavilion 742n and I just bought and installed a Antec 300 Smartpower. I have been online with The Radeon people and Computer people for four days and I still have not got this running.With the Radeon 9800 removed. Then they tell me to go into the bios setup and change the (onboard video) or (primary Video adapter ) to AGP. Well I looked at what was in the column of things and I seen (Onboard video memory) and no (onboard video).The other thing I seen was (Primary video adapter). I entered the (Primary video Adapter) and it had two spots that you could put it on.One was PCI , which it was on already.The other said AGP. So I figured it had to be moved to AGP, seeing as that was where I was plugging the card into. When I tried several different ways to do this , all I got was a monitor with a black screen and after a couple of seconds the screen went into standby mode. The green light on the button went to yellow.Also ,they told me that the (Intergrated Graphics controller) must be disabled in order for the AGP slot to work.What ever that is? So I shut it down and removed the card and here I am, looking for HELP
STEVE :bawling:
Also change primary video adapter to agp
Do you have any way to test that the 9800 is good? (ie another computer?)
There is no (onboard device Video). I will try these things and see what happens.It is not fun putting the board in and taking it back out when it does not work.
Thank you STEVE
Then boot into Safe Mode, go to Control Panel>>Add or Remove Programs and uninstall anything that says nVidia.
After that (still in Safe Mode) run the NVCleaner tool to get rid of the bits and pieces of the old driver which are likely still floating around on your computer. (Make sure you download the tool before you boot into Safe Mode.)
Shut down, physically install your new card, then boot up and install the new drivers.
Back to my problem. I went and downloaded the RV cleaner and started in the safe mode .Then i went to delete the nvidia files and it did not work on my files.(sorry).So I am going to go and try to put the onboard video memeory to ) if I can and seewhat happens.If anyone has any more good ides I relly would appreciate them
Steve
But another good question would be is the monitor pluged into the ati card
