Water Cooling
Can anybody please suggest a mid price range water cooler. It does not have to be fanless, i would actually prefer a fan, and prefably have a video card attachment as well. I am not looking for top of the market units, although i am looking for performance.
Your best bet would be to piece together a custom system, but if you'd prefer to use a kit, the swiftech kits are pretty decent. I would stay away from entry level kits such as the TT Aquarius etc, as you'd get better temps on quality air cooling. There is also a company called 'Dtek' that makes some quality kits, with heatercore radiators. Check them out too.
By building a custom kit, you'd have the option of using 1/2" tubing, better blocks, rad, pump, and much better temps. What is your budget like?
have you any idea where/how you will mount it?
At the same time I knew that if I didn't have it right in front of me I wouldn't know how to plan the installation.
When it's all said and done it was a challenge that I overcame the cheapest way possible. I'm still working on it now getting it tweaked.
The biggest realization that I came to was that when it was all said and done my temps were no better than when it was air cooled. The system is still noisy but more tolerable now and it attracts less dust than before.
So at this point you should really ask yourself if you really need watercooling.
