Dual Monitor Help
I wanna play video on my TV, but I cannot seem to get it to extend. I am using a Radeon 9700 Pro on the machine in question with Omega 5.4 Drivers.
I haven't really done this before, but I just bought the RCA cables to do this and even though everythings connected it just won't work. The video out is a S-Video connection, but I have this adapter that came with a card that makes the S-Video an RCA connection type which is what I am using.
Any ideas folks?
Any ideas folks?
1) Go to Advanced, Displays tab, enable the TV. You can choose I think whether you want it duplicated or a separate output here, so try to get it separate
2) Back on the main settings window, click on the no longer grayed "2" display and check "Extend my Windows desktop onto this monitor"
