My system: Need Help / Suggestions
ASUS A8N-SLI nVIDIA nFORCE4 SLI CHIPSET SERIAL ATA150 ATX FORM FACTOR 2xPCI-E(X16)/2xPCI-E(X1)/3xPCI/4xDDR W/SATA RAID,DUAL LAN(Gb),1394,USB 2.0 & AUDIO (CPU TYPE:AMD ATHLON 64 - SOCKET 939)NO CPU; NO EXTRA COOLING FAN; NO MEMORY
$152.00
SKU: BA21075 - - -
AMD ATHLON 64 3000+ RETAIL BOXED W/512KB CACHE 90NM (VENICE) 64-BIT SOCKET 939 W/COOLING FAN (3 YEARS WARRANTY)ARCTIC SILVER 5 COMPOUND
$152.00
SKU: BA21443 -BA19642
CRUCIAL BALLISTIX 512MB PC3200 400MHZ 2-2-2-6 184-PIN DDR DIMM W/HEAT SPREADER
$84.00
SKU: BA21029
CREATIVE LABS SOUNDBLASTER AUDIGY2 ZS PCI
$82.74
SKU: 3328976
WD 160GB 1600JD SATA-150 7200RPM 8MB (Bare drive)0.5m UV-BLUE SATA CABLE
$94.00
SKU: AA29390 -BA20504
THERMALTAKE SHARK VA7000BWA (BLACK) FULL TOWER NO POWER SUPPLY W/ SEE THROUGH SIDE WINDOW, FRONT I/O & 120mm CASE FAN x 2 EXTRA 120mm FAN(BLACK); 600W UL P/S; POWER SUPPLY INSTALLATION
$229.00
SKU: BA20849 -BA15834 -BA21051 -TEST
VIEWSONIC 19" G90FB (BLACK) .25 1600X1200 FLAT SCREEN
$205.00
SKU: BA10041
THERMALTAKE CL-P0025 SILENT TOWER COPPER BASE COOLING FAN COOLING FAN FOR AMD K7, K8 & INTEL P4 PROCESSOR W/4 PIN CONNECTOR
$39.00
SKU: BA20274
Microsoft Windows XP Professional w/sp2 #E85-03014(DSP/OEM)
$131.00
SKU: AA15070
eVGA GF6600GT 128MB PCIEXPRESS DDR3 W/TV& DUAL DVI #128-P2-N368-TX (Retail))
$169.99
SKU: AA30510
Total $1,338.73
Sorry for the really long titles and such, but I copied and pasted it from the website. All the prices come from www.mwave.com, and before you tell me to go NewEgg.com (I love that site), it wouldn't allow us to use my mother's Debit Card, and she would prefer not to use her Credit Card to order the parts. MWave is a really good website, with basically the same prices anyhow.
I already ordered an NEC CD-R/RW - DVD-R/RW drive, so that doesn't need to be mentioned. Any help/suggestions would be greatly appreciated.
$152.00
SKU: BA21075 - - -
$152.00
$84.00
SKU: BA21029
$82.74
SKU: 3328976
$94.00
$229.00
$205.00
SKU: BA10041
$39.00
SKU: BA20274
$131.00
SKU: AA15070
$169.99
SKU: AA30510
Total $1,338.73
Link:
Ultra MS Blue Dragon ATX Mid-Tower
That 600W power supply is likely overkill for your system as well.
Is there a reason you want to use that case? I've read good reviews about it, with only a few complaints (mostly this page http://www.legitreviews.com/article.php?aid=177&pid=5 ), but it seems quite expensive. The open side introduces a lot more area for dust to get into your case as well.
edit:
I've heard nothing but bad things about rebates from tigerdirect. It's quite likely that you may never get that rebate back, or it will take a rediculously long time.
edit again:
Newegg lets me use my debit card.
http://www.mwave.com/mwave/viewspec.hmx?scriteria=BA19787
That's a fairly nice case. I have one, only black. Also, you get a 500 watt X-connect powersupply with that, which is very nice. I just got a generic Ultra powersupply with mine - consider yourself lucky
No need to get that Shark thing. If you're going for cool, my brother has a Lian-Li, and those suckers are spiffy. Pretty worthless airflow, heavy as all get out, but it looks really clean-cut and nice.
At one time i was about to purchase that antec p160 case. I did my research and heard nothing but good things about it. Newegg accepts the debit card i use aswell... I would be careful of that case on tiger direct, theres multiple rebates for it and they're not too satisfactory when it comes to rebates.
$173.00
SKU: BA20954
$152.00
CRUCIAL BALLISTIX 512MB PC3200 400MHZ 2-2-2-6 184-PIN DDR DIMM W/HEAT SPREADER x2
$168.00
SKU: BA21029
$82.74
SKU: 3328976
$94.00
ULT30966-X-500-BL :: Ultra MS Blue Dragon ATX Mid-Tower Case with Clear Side Front USB and Firewire Ports and Ultra 500-Watt X-Connect Power Supply
$119.00 ($59.99 after rebate)
Item #: ULT30966-X-500-BL
$205.00
SKU: BA10041
$39.00
SKU: BA20274
$131.00
SKU: AA15070
LEADTEK GF6600GT 128MB DDR3 PCI EXPRESS W/TV & DVI,HARDWARE MONITORING # PX6600TDH (Retail)
$179.00
SKU: AA30400
Total $1198.74 (With Rebates)
Updated it a bit with the new motherboard and case options. Also added in the x2 for the RAM so noone would get confused.
It says something about a phone number located on the back of the card that is missing from my mom's card. I will look to see if my debit card has it when it comes in, but it hasn't arrived yet.
Yes, that was very difficult to find on the card i used. It was half cutten off. Who is the Company?(Mastercard, etc.)
Ok, good. The card i used was mastercard as well and it was difficult to find the number...well not difficult, i just didnt know if it was the right one. On the back of the card(where the signature usually goes) above the black bar where it is swiped should be some words up there that are half legible. The phone number on the card that i used was 1-800-4-cirrus. Yours may differ. Good luck and get back to me on whether yours has it or not.
I can almost guarentee it, put it on there, and im sure itll work.
No problem
