power up problems- viral or hardware?
have looked at similarly titled threads and can't see a similer prob: basically have five month old dell inspiron laptop. has worked fine until recently when pressing the power on button has become unreliable. sometimes nothing happens, no power light, fan etc, then if i keep pressing it eventually it will start without any apparent problems.
initially i assumed this must be a loose connection and was planning to send the laptop back to dell but am made slightly suspicious because the problem started soon after i got broadband internet connection and because the time taken for the power button to work seems to be increasing each time i try to restart the computer. could this be caused by a virus?
dell haven't been much help and i really need my computer for a project at the moment so am reluctant to send it off for repair unless absolutely necessary. can anyone please give me some advice?
thanks for any posts
Can you ever get it to power up?
Make sure that you are somewhere that you can leave it pluged in and running.
Run your anti-virus, with updates, as well as anti-spyware.
I think that your issue is hardware, returning is your only real option.
I have my doubts that it is a motherboard issue, thats what Dell says every issue is when it comes to their laptops.
