help with wireless network
first of all, heres my setup: Speedstream DSL modem, going to a 2wire 4-port router, 2 computers wired out from the 2wire, and then a Linksys BEFW11S4 plugged into the 2wire.
I'm trying to get 2 laptops to connect thru the new linksys router. I have got them configured (im pretty sure), and it says Connected on both laptops. On both laptops, I CAN go to the Linksys router settings (192.168.1.1), but I can't go to any websites!! Please help me get this configured.
oh also- wired connection thru the linksys did work before, but now it doesnt
It should be in the Linksys.
The ROUTER wire should be connected into a lan port of the Linksys.
If the Wan wire is in the Linksys then try rebooting the Cable Modem, this will allow the Status page on the Linksys to update with the Wan settings
Where is DHCP enabled? It sould be at the Linksys and not at the router. Also are you using DHCP or Static IP? Change to DCHP in the NIC settings.
I'm new to setting up a wireless network, and I've read up on the board that to secure the network, one has to use WEP, MAC filitering, and diable SSID.
But with no previous wireless networking experience, how do I go about doing that?
http://www.linksys.com/products/product.asp?grid=33&scid=35&prid=544
Click on the Wireless tab, and then the Wireless Security tab. Enable, and then select WEP security mode. Under WEP Key 1, type a 10-digit hex code. (letters A-F, numbers 0-9). EX: 12345abcde Then click Save Settings at the bottom, and you're all set. (Refer to the picture below)
The router isn't mine and the even more clueless friend couldn't get the wireless working in the first place!
I'm just hoping that they haven't played around with the router and changed the password and forgotten about it...
How about MAC filitering and disabling SSID?
Can you please teach me now so I won't have to come back in the future and ask again?
dont mind me ^^
back to routers- if he forgets the password, just hold down the reset button on the back of the router for about 10 seconds, and its all back to factory settings. (blank username, password= admin)
