sudden problem
iHatePopUpsiHatePopUps Singapore
edited July 2005 in Nerdery
Well, it's a routine that every time i turn on the PC i'll hit Ctrl+Alt+Del to get the task Manager up and end all processes that i don't use. The problem is, all of a sudden since yesterday, my Ctrl+Alt+Del command doesn't work anymore! I've tried to "Search" Task Manager on my PC, but it can't be found! I've not downloaded nor deleted anything over the past week, so how can i get the Task Manager back???
  • botheredbothered Manchester UK
    edited July 2005
    Don't know about Ctrl,Alt, del not working but why not run msconfig and turn those processes off anyway?
  • iHatePopUpsiHatePopUps Singapore
    edited July 2005
    ok...but if say some programs were to freeze, how can i handle them if i don't have the task manager?? any way i can try to get it back?
    edited July 2005
    Have a look here-http://www.short-media.com/forum/archive/index.php/t-10681.html
    Can you right click the task bar to get it up?
    ceratain spyware disables the task manager, scan your system w/ adaware, spybot and antivirus pgm.
