Help!!!!
When i play video, my computer will make the screen dark(only inside the player...)
i have tried to take another video to test but it also white screen.... i have tried to roll back my video card's driver but it also white screen... i have tried
to reinstall the window but it seems that it didn't work also...
All player have the same porblem, like Window Media Player, Real player and so...
All file type also have the same porblem, like, wmv,rm,rmvb,vob....
Does any one have the same porblem like me????
What will you do????
Thankyou guys!!!!!
System spec. :
CPU: AMD Athlon XP 3000+
Video Card: Inno3d Nvidia FX5500
Thankyou guys!!!!!
System spec. :
So, do you guys know whats happening???
Thankyou!!!!!
If that doesn't help, I know you tried a driver rollback, try cleaning out all of the drivers with a tool like NVCleaner, then reinstall the latest ones.
Good luck.
But if i install the driver, then it will have the white screen....
Is that crazy of Nvidia's driver???
