problem configuring wireless network
leishi85leishi85 Grand Rapids, MI Icrontian
edited July 2005 in Nerdery
ok, so i got a netgear WGR614 wireless router, and got it hooked up to my existing router so i can use it as an AP and at the same time add more ports to my current network. I disabled the DHCP on the netgear and set an IP of 192.168.1.99, and so far, i get internet access from the LAN ports on the netgear fine, but when i try to access the netgear router to config the wireless settings, i can not get into the config page at all, no prompt for username or password, just page not found,
any ideas guys?
  • ArmoArmo Mr. Nice Guy Is Dead,Only Aqua Remains Member
    edited July 2005
    u may have to unplug the netgear from everything else and ude the defualt ip 192.168.1.1 to access it and set it up for the 1st time. ive had to do that when configing a few linksys routers together for a LAN party
  • leishi85leishi85 Grand Rapids, MI Icrontian
    edited July 2005
    yeah, i just did that, config the wireless part first and then have it all connected.
