I have a problem and need help PLEASE
edited August 2005 in Nerdery
I have been having a big problem with a computer and I just cant seem to correct it. My brother bough a Tiny computer and as you all probably know the have folded, with no disks etc my brother shouted for me to help. I have managed to get the computer up and running but dont have any sound. Please help
  • TexTex Dallas/Ft. Worth
    edited August 2005
    We would need more info. Try opening it up and seeing if the motherboard has anything printed on it (make/model) to help us see what exactly is needed.
    You might take a wild guess if its onboard sound and gets a ac97 based sound. And try and load those drivers.
    Technical Support - 0906 558 0234 (£1/min)
    Thats also listed as the tech support number time/tiny are directing folks to for now.
    Google for "Tiny computer tech support" and there apears that many UK vendors are trying to pcik up the client base for support.
    You might try
    http://www.pciq.biz/soho.asp
    for starters.
    Tex
  • edited August 2005
    On the motherboard it has MS-6777VER:1 and N1996. The silver box inside says Foxconn however I have found out that it isnt the manufacturer. Will give the ac97 a try first. Thanks
    edited August 2005
    The board is a MSI K7N2GM-L
    http://www.msicomputer.com/product/p_spec.asp?model=K7N2GM-L&class=mb
    Sound is a realtek ALC650. Thats a realtek ac97 based driver
    Try the ac97 driver from msi's site found here.
    http://www.msi.com.tw/program/support/driver/dvr/spt_dvr_list.php?part=1&kind=3&CHIP=3&ID=5
    You have it running sort of but I would get all the latest drivers foir the MB and chipset etc.. from MSI also.
    Tex
