Help. Drive using PIO mode insteaed of ATA133
Hello,
I recently purchased a new Maxtor 250GB drive. (Maxtor 6L250R0)
I already have a maxtor 30GB drive. (Maxtor 53073H4)
I have set them up with the following configuration in the BIOS.
Primary IDE (80 pin cable)
Master: 30GB Maxtor (Don’t want to reinstall windows and can't be bothered to do a partition copy)
Slave: 250GB Maxtor
Secondary IDE (40 pin cable)
Master: Plextor 708A DVD Writer
Slave: Some CDwriter
The boot up screen that you see just after you turn your PC on indicates the following setup has been configured.
Primary IDE
Master: LBA ATA100
Slave: LBA ATA133
Secondary IDE
Master: ATA33
Slave: PIO 4
The Award BIOS supports the following options
VIA Onchip IDE Device (Yes, I have installed the recommended VIA 4-in1 drivers)
Onchip IDE Channel 0 – Enabled
Onchip IDE Channel 1 – Enabled
IDE Prefetch Mode – Enabled
Primary Master PIO – Auto (Mode 0 – 4 also available)
Primary Slave PIO – Auto (Mode 0 – 4 also available)
Secondary Master PIO – Auto (Mode 0 – 4 also available)
Secondary Slave PIO – Auto (Mode 0 – 4 also available)
Primary Master UDMA – Auto (Disabled, UDMA33, UDMA66, UDMA100, UDMA133 also available)
Primary Slave UDMA – Auto (Disabled, UDMA33, UDMA66, UDMA100, UDMA133 also available)
Secondary Master UDMA – Auto (Disabled, UDMA33, UDMA66, UDMA100, UDMA133 also available)
Secondary Slave UDMA – Auto (Disabled, UDMA33, UDMA66, UDMA100, UDMA133 also available)
CDROM UDMA Support – Enabled
I have tried both the Auto setting and the UDMA133 setting for the Primary Slave but once I boot up into Windows I see the following when I go to
Device Manager->Primary IDE Channel->Advanced Settings
Device 0
Type: Auto Detection
Transfere Mode: DMA If Available
Current Mode: UDMA 5
Device 1
Transfere Mode: DMA if available
Current Transfere Mode: PIO
It seems the problem is with Windows, since at bootup it correctly identifies LBA ATA133 for the drive mode.
I have seaqrched through the windows help center, and found nothing relevant. Can someone please help me solve this? My 250GB brand new drive is clocking in at about 2.5MB per sec. This is appallingly slow. I feel like shooting myself every time I watch a file copy between drives.
Please Help ….
Slave: 250GB Maxtor
Primary IDE
Master: LBA ATA100
Slave: LBA ATA133
Secondary IDE
Master: ATA33
Slave: PIO 4
Device 0
Device 1
Please Help ….
Once Windows decides that the drive doesn't like UDMA, a fresh start is the only way around it.
Thank you kind sir ..
Glad you got it going.
The drive he was bitching about not being in ata133 mode was a cd burner?
And it will downgrade the drive to PIO mode again if it gets errors. Since this is some "no name" cd burner it may even be a PIO mode drive to strat with.
Tex
I was just using the illustration that a bum CD can cause Windows to downgrade the DMA settings for the drive. It's the most common cause of this "feature" in WinXP, though certainly not the only one.
Erm, the only thing running slow there is the Secondary Slave which is the CD-Writer which wouldn't effect the speed of the transfers between the two drives on the Primary IDE controler...
uhhhhh
He did.
The title of this thread is "Help. Drive using PIO mode insteaed of ATA133".
And his boot screen shows
Slave: 250GB Maxtor
Primary IDE
Master: LBA ATA100
Slave: LBA ATA133
Secondary IDE
Master: ATA33
Slave: PIO 4
Tex
But seriously ... Prof, you mentioned there is more than one reason this comes back. Would you mind enlighting the unenlightened. It seems my problem has returned.
I am fairly convinced that there is a problem with the 'explorer' progam because I notice the computer revert to its terrible speeds after terminating it. Yes, yes .. Of course I have a reason... It hogs 99% of system resources clocks up to 200MB of memory and I can't do anything else on my PC. After selecting start new task 'explorer' from the task manager everything seems ok.
I took a dreadful step and installed service pack 2 since Im fairly sure any corruption that may have occured in the 'explorer' program will probably be replaced and hopefully no longer exist. I will wait a few days to see if the problem returns, but in the meantime if anyone has any ideas as to why it may return or why explorer would do such ghastly things - I would love to hear.
Scorpion.
Another common cause of this is having a corrupt video file on the drive, or even an extremely large video file which is not corrupt. When Windows can't generate the preview for the fancy-pants icon view, it runs Windows Explorer CPU usage right up to the max. See if any of this applies to your situation.
Yes, this may be the cause. I have noticed this happens when I click on a folder filled with .avi files.
Do you know a simple way to determine what file is the offending one without copying them 1 by 1 to a single folder and then trying to recreate a situation that you definately dont want to happen?
I always use the detail view, not the fancy stuff, so I doubt it has to do with file size. More likely corruption.
Scorpion
Then cut-and-paste half of them to a new folder. Rename the extensions to .avi on the files in one folder and see if the problem recurs. If it does you'll know the stinker is among the ones you just renamed; if not, it will be among the ones still ending in .av_. Repeat the process until you've narrowed the list of suspects down to a small number, then try them one-by-one.
If you read through some of those Google links I posted you'll find that it can be tricky deleting the troublemaker. If you need help with that let us know; there are ways around that problem, too.
I have used this batch renamer with great success.
OK, I'll do it the long way ...
Hope it works out OK.
His primary slave isnt in PIO mode is it?
Thats the slave on the secondary channel thats in PIO mode and its a cdrom.
The maxtor is ata133. Check again. This is what I see...
Primary IDE
Master: LBA ATA100
Slave: LBA ATA133
The only PIO mode drive is the slave on the SECONDARY ide. Thats the cd burner.
There is no hard drive in PIO mode.
Which is what Enverex also pointed out.
There is no way on this earth to get the secondary slave into ata133 mode. Because its a friggin CD not a hard drive.
Tex
Read it again. And the Primary Slave drive is in what mode?
Unless you think Maxtor makes a 250GB burner.
